Hi all!
I'm Pietro and this is my first message here! So be patient if my information is
lacking in something.
I try to run r.cost on grass70 from svn but I have this output message:
GRASS GIS 7.0 svn:40557-40571
$ r.cost -k input=dtm_dist@trentino output=provarcost70
start_rast=viafor@trentino
Will need at least 0.00 MB of disk space
Will need at least 0.00 MB of memory
WARNING: segment_setup: illegal segment file parameters
Reading raster map <dtm_dist@trentino>, initializing output...
Segmentation fault
Grass6.4 work fine! And I get this:
GRASS GIS 6.4.0RC5
Reading raster map <dtm_dist@trentino>...
100%
Initializing output...
100%
Reading raster map <viafor>...
100%
Finding cost path...
100%
No data
Writing raster map <provarcost>...
100%
r.cost complete. Peak cost value: 132.490
More Details about my system:
OS: Linux
Distribution: Archlinux
kernel: 2.6.32-ARCH
gcc: 4.4.2 20091208 (prerelease) (GCC)
Using built-in specs.
Target: x86_64-unknown-linux-gnu
Configured with: ../configure --prefix=/usr --enable-shared --enable-
languages=c,c++,fortran,objc,obj-c++,ada --enable-threads=posix --
mandir=/usr/share/man --infodir=/usr/share/info --enable-__cxa_atexit --disable-
multilib --libdir=/usr/lib --libexecdir=/usr/lib --enable-clocale=gnu --disable-
libstdcxx-pch --with-tune=generic
Thread model: posix
Architecture compile flags:
CARCH="x86_64"
CHOST="x86_64-unknown-linux-gnu"
CFLAGS="-march=core2 -O2 -pipe"
CXXFLAGS="-march=core2 -02 -pipe"
MAKEFLAGS="-j3"
Compile grass with:
./configure --prefix=/opt --with-gdal="/usr/bin/gdal-config" --with-sqlite --
with-python --with-wxwidgets="/usr/bin/wx-config" --with-blas --with-lapack --
with-postgres --with-proj-libs="/usr/lib" --with-proj-includes="/usr/include" --
with-proj-share="/usr/share/proj" --with-fftw --with-fftw-
includes="/usr/include" --with-fftw-libs="/usr/lib" --with-freetype=yes --with-
freetype-includes="/usr/include/freetype2/" --with-pthread
Any hint?
Pietro
Oops. I will look into it, works just fine here, also Linux 64bit.
what does g.region -p say?
Markus M
Pietro Zambelli wrote:
Hi all!
I'm Pietro and this is my first message here! So be patient if my information is lacking in something.
$ r.cost -k input=dtm_dist@trentino output=provarcost70 start_rast=viafor@trentino
Segmentation fault
GRASS GIS 6.4.0RC5
$ r.cost -k input=dtm_dist@trentino output=provarcost start_rast=viafor@trentino
100%
100%
100%
100%
No data
100%
OS: Linux
kernel: 2.6.32-ARCH
Thread model: posix
CARCH="x86_64" CHOST="x86_64-unknown-linux-gnu" CFLAGS="-march=core2 -O2 -pipe" CXXFLAGS="-march=core2 -02 -pipe"
MAKEFLAGS="-j3"
Compile grass with:
Any hint?
Pietro
grass-dev mailing list
grass-dev@lists.osgeo.org
