[GRASS-dev] segmentation fault with r.surf.idw -e
Hello devs,
When running r.surf.idw with the e flag, I am getting a segmentation fault (core dumped).
I am on Ubuntu 16.04 and I am using GRASS GIS from trunk
So, if I run the following:
g.mapset -c mapset=exercise
g.region -p raster=elev_state_500m@PERMANENT
v.to.rast input=precip_30ynormals@PERMANENT output=weatherstations use=attr attribute_column=annual
r.mapcalc expression="rainfall_int = int(rainfallstations*10)"
r.surf.idw -e input=rainfall_int output=cv_errormap
Output is:
Reading raster map <rainfall_int>...
100%
Interpolating raster map <cv_errormap> (669 rows)...
Segmentation fault (core dumped)
[Raster MASK present]
It works with a smaller region, but the region used in this example or the number of points isn't that big I would say? Am I doing something wrong or should I file a bug report?
Best wishes,
Paulo
Same but setting debug=3:
GRASS 7.3.svn (nc_spm_08_grass7):~ > g.gisenv set="DEBUG=3"
D1/3: G_set_program_name(): g.gisenv
D3/3: G_option_to_separator(): key = separator -> sep = '/'
GRASS 7.3.svn (nc_spm_08_grass7):~ > r.surf.idw -e input=rainfall_int output=cv_errormap
D1/3: G_set_program_name(): r.surf.idw
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell/cv_errormap
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/WIND
D2/3: file open: read (mode = r)
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 318500
D3/3: region item: south: -16000
D3/3: region item: east: 963000
D3/3: region item: west: 124000
D3/3: region item: cols: 1678
D3/3: region item: rows: 669
D3/3: region item: e-w resol: 500
D3/3: region item: n-s resol: 500
D3/3: region item: top: 1.000000000000000
D3/3: region item: bottom: 0.000000000000000
D3/3: region item: cols3: 1678
D3/3: region item: rows3: 669
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 500
D3/3: region item: n-s resol3: 500
D3/3: region item: t-b resol: 1
D1/3: G_find_raster(): name=MASK mapset=exercise
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell/MASK
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cellhd/MASK
D3/3: region item: format: 0
D3/3: region item: compressed: 2
D1/3: G_find_raster2(): name=MASK mapset=exercise
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/fcell/MASK
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/g3dcell/MASK
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/MASK/gdal
D3/3: create window mapping (1678 columns)
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/MASK/null
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/MASK/nullcmpr
D1/3: G_find_raster2(): name=rainfall_int mapset=
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/SEARCH_PATH
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/PERMANENT
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/bioclim
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/landsat
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/modis_lst
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/user1
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cellhd/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/PERMANENT/cellhd/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/bioclim/cellhd/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/landsat/cellhd/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/modis_lst/cellhd/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/user1/cellhd/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell/rainfall_int
D3/3: region item: format: 1
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/fcell/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/g3dcell/rainfall_int
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/rainfall_int/gdal
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/rainfall_int/null
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/rainfall_int/nullcmpr
100%
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/GDAL
D2/3: G__temp_element(): .tmp/HP-Z600 (tmp=0)
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/.tmp/HP-Z600/5463.0
D2/3: G_tempfile_pid(): /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/.tmp/HP-Z600/5463.0
D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/.tmp/HP-Z600/5463.1
D2/3: G_tempfile_pid(): /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/.tmp/HP-Z600/5463.1
GRASS 7.3.svn (nc_spm_08_grass7):~ > ^C
On Sat, Nov 4, 2017 at 6:56 PM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hello devs,
(core dumped).
Output is:
100%
it crashes on this line:
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_2/raster/r.surf.idw/main.c#L431
but I would need to dig into what the code is actually doing there.
Check whether there is already a ticket for this, but otherwise,
please create new one.
Anna
Best wishes,
Paulo
output=cv_errormap
100%
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
