I'm trying to use r.to.vect but I got a Segmentation fault...
I'm using GRASS7 (at revision 57694) on the North Carolina dataset
[0], just enter in the user1 mapset and run:
Any hints? I'm the only one that have this problem?
I did the distclean and recompile everything but the error is still there...
I'm running 64bit Linux.
I cannot reproduce this problem (Debian GNU/Linux unstable 64bit).
Probably more detailed info (gdb output) will be needed to solve this
issue.
On Sun, Sep 15, 2013 at 2:28 PM, Martin Landa <landa.martin@gmail.com> wrote:
issue.
issue.
