when i try to select a feature with the “select vector feature” button from map display, I get an Error pop up that reads:
Error occured during calling of handler: _onMapClickHandler
Handler was unregistered.
Reason: VectorSelectBase instance has no attribute ‘map’
File “/usr/local/grass-7.1.svn/gui/wxpython/mapwin/base.py”, line 191, in HandlersCaller
handler(event)
File “/usr/local/grass-7.1.svn/gui/wxpython/gui_core/vselect.py”, line 187, in onMapClickHandler
vWhatDic = self.QuerySelectedMap()
File “/usr/local/grass-7.1.svn/gui/wxpython/gui_core/vselect.py”, line 272, in QuerySelectedMap
message=(“Failed to query vector map(s) <%s>.”) % self.map)
AttributeError: VectorSelectBase instance has no attribute ‘map’
Thanks
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
when i try to select a feature with the "select vector feature" button
Reason: VectorSelectBase instance has no attribute 'map'
File "/usr/local/grass-7.1.svn/gui/wxpython/mapwin/base.py", line
handler(event)
File "/usr/local/grass-7.1.svn/gui/wxpython/gui_core/vselect.py",
line 187, in _onMapClickHandler
message=_("Failed to query vector map(s) <%s>.") % self.map)
AttributeError: VectorSelectBase instance has no attribute 'map'
I cannot reproduce using freshly checked out trunk and the NC dataset.
BTW, two remarks for enhancement:
- It would be nice if the tool allowed to select also by drawing a polygon, not only by clicking.
- There is no close button on the little window listing the selected features.
browsing the add ons i saw v.out.png is no more in trunk and i gave it a try :
import os
import sys
from grass.script import core as grass
from grass.script import gisenv
from grass.pygrass.modules.shortcuts import display as d
from grass.pygrass.modules.shortcuts import general as g
