[GRASS-dev] selecting lines boundary-wise
Hi list,
I'm trying to export the boundaries of a vector file, but would like
to avoid duplication of common boundaries. It's easy to know which
boundaries limit a given area, but how can I extract only one
boundary. For example, area 1 has boundaries 6,7,9 while for area 2
these are 8,9. Is there a way to extract the lines of boundary 8 only
for area 2 in order to avoid duplicating it? A comination of
Vect_get_area_boundaries(&Map,area,List) with something else?
Jaime
A combination of v.dissolve + v.overlay?
note that grass only keeps a single boundary line between two areas, it
doesn't duplicate them, 1 for each area. see 'v.clean tool=rmdupl'
(well it can handle input data like that but complains that the data is
topologically unclean)
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
