Dear devs,
i would like to implement sqlite database support as separated file for each vector map. Similar to the dbf approach but with sqlite. Other databases are no option in my case.
The reasons for this approach are the following:
- The temporal vector algebra would hugely benefit from separated sqlite vector map files, since it can compute in parallel, no race condition or serial processing of database requests is required
- Vector maps can easily be moved between locations with full database content, no data loss. Simply the vector map directory must be archived
- Merging of mapsets is much easier, since the vector map sqlite databases don’t need to be merged, only copied
This approach would be implemented in addition to all other existing approaches.
However, i don’t know were to start with this, any hints or suggestions?
Best regards
Soeren
Hei Sören,
I ran into this recently too, with lots of “Busy SQLite” warnings, when I tried to modify two or more vector maps in parallel.
So the work you are planning to do would be very much appreciated.
However, in order to not break existing modules like v.db.join, queries across SQLite DBs would have to be supported.
Here the “attach” keyword might be a starting point for required additions to e.g. v.db.join: http://sqlite.org/lang_attach.html
It is probably also necessary to think about how (or more precise where) tables are supposed to be handled which are not linked to a vector map… Will all non-map tables be saved in their own SQLite DB file?
Do you plan to store tables linked to additional layers in the same SQLite file as the vector map?
How would modules like db.tables or db.copy behave? What happens if you connect the attribute table of map a (or just table a) to map b?
Just some thoughts …
Stefan
Dear devs,
Best regards
Soeren
On Fri, Sep 9, 2016 at 11:06 PM, Sören Gebbert
<soerengebbert@googlemail.com> wrote:
Dear devs,
* The temporal vector algebra would hugely benefit from separated sqlite
* Vector maps can easily be moved between locations with full database
* Merging of mapsets is much easier, since the vector map sqlite databases
don't need to be merged, only copied
approaches.
However, i don't know were to start with this, any hints or suggestions?
This is implemented in G6.3, maybe also early versions of G6.4, but
has been removed at some stage, no idea why.
Have a look at lib/vector/Vlib/field.c, there at the fns
Vect_subst_var()
and
Vect_get_dblink()
Essentially, all that is needed is a corresponding entry in $LOCATION_NAME/VAR:
instead of
DB_DRIVER: sqlite
DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
try
DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/sqlite/sqlite.db
HTH,
Markus M
On Sat, Sep 10, 2016 at 5:33 PM, Markus Metz
Dear devs,
approaches.
Vect_subst_var()
and
Vect_get_dblink()
in $LOCATION_NAME/$MAPSET/VAR:
instead of
DB_DRIVER: sqlite
try
HTH,
Markus M
On Sat, Sep 10, 2016 at 11:24 PM, Sören Gebbert
Mi Markus,
[snip]
$LOCATION_NAME/VAR:
instead of
DB_DRIVER: sqlite
try
HTH,
This helped a lot, thank you. Simply running:
db.connect driver=sqlite
database='$GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/sqlite.db'
will do the job. This can be run right after mapset creation.
And it works nicely. It seems that most of the v.db.* commands work with
vector map specific database files. The db.* commands seemed work as well,
if the database path is provided at the command line.
I skipped the sqlite directory in the vector map path ($MAP/sqlite/sqlite.db
-> $MAP/sqlite.db), since this directory must be created when a new vector
is opened, hence the vector-open-new functions must be modified to support a
separate sqlite directory. With the simple solution the directory fsync()
behavior of sqlite will force now all vector map specific files to be
flushed to disc. This may be a performance problem.
sqlite might not open the (new) database at all if it can not fsync()
the directory. That will not result in performance penalty but in a
fatal error, therefore it is a good idea to keep the sqlite db in a
separate folder.
The GRASS sqlite driver attempts to create the sqlite directory
(db__driver_open_database() in trunk/db/driver/sqlite/db.c) if the
directory does not exist, therefore Vect_open_new*() should not need
any modification.
This solution may be sufficient for my needs, no modification needed in the
code ... except, v.info should show the database path of a vector map if
extended metadata is required.
Many thanks for your help
Best regards
Soeren
Markus M
