[GRASS-dev] SESSION_MANAGER environment variable not defined
Dear GRASS-dev,
I have started seeing this error:
Error - Debug: Failed to connect to session manager: SESSION_MANAGER environment variable not defined
when starting GRASS GIS that I have compiled myself (both 6.4.x and 7.1-svn), and do not know why. I am running Ubuntu 14.10. Never seen anything like this before. Suggestions?
Thanks!
Andy
Andrew D. Wickert
INSTAAR & Geological Sciences, University of Colorado Boulder
Now at:
Universität Potsdam
Institut für Erd- und Umweltwissenschaften
Haus 29, Rm. 1.53
Karl-Liebknecht-Str. 24-25
14476 Potsdam-Golm, Deutschland
On Mon, Jan 12, 2015 at 12:28 PM, Andy Wickert <wickert@colorado.edu> wrote:
Dear GRASS-dev,
Which operating system do you use? It doesn't seem to come directly
from GRASS GIS.
I found (random links)
http://ubuntuforums.org/showthread.php?t=1874423
http://trac.wxwidgets.org/ticket/16024
Thanks Markus. Ubuntu 14.10. I agree that the core of this is not a GRASS problem, and yet it appears only when starting GRASS GIS. On opening a location, the GUI shows up, but no dialog windows (e.g., add layer) appear.
Andy
telephone email
Dear GRASS-dev,
Which operating system do you use? It doesn’t seem to come directly
from GRASS GIS.
Andy, are you using wxPython 3?
Markus, you’re a genius! I just tried starting the version of GRASS available on the apt repositories and got this message:
awickert@dakib:~$ grass
Cleaning up temporary files …
Starting GRASS …
ERROR: wxGUI does not support wxPython 3.0.0.0 yet.
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
So I think that what you are saying is that wxPython 3 somehow becomes the default / interferes with GRASS. I did:
awickert@dakib:~$ sudo apt-get remove python-wxgtk3.0
and now everything works. Well, hopefully my removal of wxPython 3 doesn’t break something else, so hm, is there a way to ensure that GRASS GIS always looks for wxPython 2?
Thank you!!
Andy
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
On 13/01/15 11:02, Andy Wickert wrote:
Markus, you're a genius! I just tried starting the version of GRASS
Cleaning up temporary files ...
Starting GRASS ...
Hit RETURN to continue...
doesn't break something else, so hm, is there a way to ensure that GRASS
The idea is rather to try to solve any errors concerning wxPython 3 as it is more and more becoming the default in Linux distributions. Anna has been quite active in trying to solve any specific wxPython3 issues.
On my Debian Testing system I have Python 2.7.8 and wxPython: 3.0.1.1 and I do not see your error. So it would be interesting to explore what happens on your system. What graphical environment are you running in ? What does 'echo $SESSION_MANAGER' in a terminal give you ?
Moritz
After the uninstall, I have:
Python 2.7.8
wxPython 2.8.12.1
‘echo $SESSION_MANAGER’ returns nothing both inside and outside the GRASS GIS environment in terminal.
On Tue, Jan 13, 2015 at 11:50 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Starting GRASS …
On my Debian Testing system I have Python 2.7.8 and wxPython: 3.0.1.1 and I do not see your error. So it would be interesting to explore what happens on your system. What graphical environment are you running in ? What does ‘echo $SESSION_MANAGER’ in a terminal give you ?
Moritz
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Python 2.7.8
wxPython 2.8.12.1
'echo $SESSION_MANAGER' returns nothing both inside and outside the GRASS
We checked here on an Ubuntu 14.4 and it is also empty while Fedora
20/XFCE reports
local/unix:@/tmp/.ICE-unix/1934,unix/unix:/tmp/.ICE-unix/1934
What if you set
export SESSION_MANAGER=1
On Tue, Jan 13, 2015 at 2:13 PM, Markus Neteler <neteler@osgeo.org> wrote:
What if you set
... of course along with wxpython3... (to be reinstalled at your end).
Thanks for the patience of testing but this is important for us.
Are you using Unity ? GNOME ? KDE ? A session over ssh ?
I'm really no windows management and graphical environment expert, but apparently some windows managers do not set this variable.
Moritz
Python 2.7.8
wxPython 2.8.12.1
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
        Starting GRASS ...
        becomes
        that GRASS
    issues.
    give you ?
    Moritz
Hi Markus and Moritz and all,
Moritz – Unity.
Markus –
Starting GRASS GIS…
_IceTransOpen: Unable to Parse address 1
12:20:02 AM: Debug: Failed to connect to session manager: Could not open network socket
So the blank “NetworkManager” in Unity is definitely the culprit in my mind.
Andy
On Tue, Jan 13, 2015 at 2:29 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
I’m really no windows management and graphical environment expert, but apparently some windows managers do not set this variable.
Moritz
Python 2.7.8
wxPython 2.8.12.1
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
Starting GRASS …
becomes
that GRASS
issues.
give you ?
Moritz
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Moritz -- Unity.
Markus --
Starting GRASS GIS...
network socket
So the blank "NetworkManager" in Unity is definitely the culprit in my
mind.
just to make sure I understand, the gui opens (layer manager + window), but
adding map layer doesn't work? What else doesn't work? Do you get any other
error in the terminal or gui console? I just want to make sure there is no
other reason behind this. I was not really able to understand what the
weird error means by googling, but it seems that sometimes it could be
harmless.
Anna
Andy
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Moritz
Python 2.7.8
wxPython 2.8.12.1
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
        Starting GRASS ...
        becomes
3
        that GRASS
    issues.
    give you ?
    Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
2015-01-14 2:08 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
network socket
mind.
other reason behind this. I was not really able to understand what the weird
error means by googling, but it seems that sometimes it could be harmless.
yesterday I switched to wxPython3 and I am getting this debug message
too when starting wxGUI...
01:16:47 AM: Debug: Failed to connect to session manager:
This debug message has no effect on my PC. Martin
Martin Landa
http://gismentors.eu/mentors/landa
Hi Anna and Martin,
Anna – You are absolutely correct. What doesn’t work is anything that requires opening another window after GRASS GIS starts. No other errors show up in the GUI console. This applies to the version that I compiled myself. The version that I got from apt-get won’t launch the GUI at all and (as noted above) prints the following message:
Martin – just to double-check, did you try adding a layer and have success in doing that? And what OS (and, if applicable, desktop) are you using?
Andy
On Wed, Jan 14, 2015 at 9:31 AM, Martin Landa <landa.martin@gmail.com> wrote:
network socket
mind.
adding map layer doesn’t work? What else doesn’t work? Do you get any other
too when starting wxGUI…
Martin Landa
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
2015-01-14 10:29 GMT+01:00 Andy Wickert <wickert@colorado.edu>:
which version are you using?
Martin -- just to double-check, did you try adding a layer and have success
Fresh GRASS 7.0.0svn works together with wxPython 3 for me. Using
Debian GNU/Linux unstable. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
apt-get version is 6.4.3.
The version giving me problems with wxPython 3 is 7.1.svn
Andy
On Wed, Jan 14, 2015 at 11:12 AM, Martin Landa <landa.martin@gmail.com> wrote:
Martin Landa
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Sorry, actually, they both give me problems, but the version that allows the GUI to start but not the add-layer dialog to open is 7.1.svn.
Andy
On Wed, Jan 14, 2015 at 2:55 PM, Andy Wickert <wickert@colorado.edu> wrote:
Andy
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Martin Landa
Andy
I am using Ubuntu 14.04 with wxPython 2.8 but I have self-compiled wxPython
3.0.1.1 for testing purposes. I don't have any similar problems. How did
you get wxPython3, I don't think it's in standard repositories?
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
wrote:
Andy
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
wrote:
success
Martin Landa
Hi Anna,
Sorry I let this languish!
It installed without me explicitly asking it to be – perhaps it was a dependency for something? In any case, it has made its way into my standard set of packages. I wonder if there is something between it and Unity keeping SESSION_MANAGER blank.
Andy
On Wed, Jan 14, 2015 at 4:16 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Andy
I am using Ubuntu 14.04 with wxPython 2.8 but I have self-compiled wxPython 3.0.1.1 for testing purposes. I don’t have any similar problems. How did you get wxPython3, I don’t think it’s in standard repositories?
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Andy
Andrew D. Wickert
Now at:
Universität Potsdam
Haus 29, Rm. 153
Martin Landa
