[GRASS-dev] set null compression permanently
I just tried to enable compression of null files, using within a session:
export GRASS_COMPRESS_NULLS=1
r.null -z map=mymap
This works fine, but how can I set this permanently. Can I for example use g.gisenv for that? Or do I need to set this every time when starting a new session?
Paulo
2017-01-10 17:55 GMT+01:00 Paulo van Breugel <p.vanbreugel@gmail.com>:
session?
it's not GRASS variable. Environmental variables can be defined in
$HOME/.grass7/bashrc (or env.bat on Windows). In your case
put to bashrc/env.bat file. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Ah, ok, thanks!
