I have sync'ed the SHAPELIB copy from OGR in
lib/external/shapelib/
Changes:
dbfopen.c:
* Revision 1.67 2006/06/17 00:24:53 fwarmerdam
* Don't treat non-zero decimals values as high order byte for length
* for strings. It causes serious corruption for some files.
* http://bugzilla.remotesensing.org/show_bug.cgi?id=1202
* Revision 1.66 2006/03/29 18:26:20 fwarmerdam
* fixed bug with size of pachfieldtype in dbfcloneempty
* Revision 1.65 2006/02/15 01:14:30 fwarmerdam
* added DBFAddNativeFieldType
* Revision 1.64 2006/02/09 00:29:04 fwarmerdam
* Changed to put spaces into string fields that are NULL as
* per http://bugzilla.maptools.org/show_bug.cgi?id=316.
* Revision 1.63 2006/01/25 15:35:43 fwarmerdam
* check success on DBFFlushRecord
* Revision 1.62 2006/01/10 16:28:03 fwarmerdam
* Fixed typo in CPLError.
* Revision 1.61 2006/01/10 16:26:29 fwarmerdam
* Push loading record buffer into DBFLoadRecord.
* Implement CPL error reporting if USE_CPL defined.
* Revision 1.60 2006/01/05 01:27:27 fwarmerdam
* added dbf deletion mark/fetch
shpopen.c:
* Revision 1.48 2006/01/26 15:07:32 fwarmerdam
* add bMeasureIsUsed flag from Craig Bruce: Bug 1249
* Revision 1.47 2006/01/04 20:07:23 fwarmerdam
* In SHPWriteObject() make sure that the record length is updated
* when rewriting an existing record.
* Revision 1.46 2005/02/11 17:17:46 fwarmerdam
* added panPartStart[0] validation
* Revision 1.45 2004/09/26 20:09:48 fwarmerdam
* const correctness changes
* Revision 1.44 2003/12/29 00:18:39 fwarmerdam
* added error checking for failed IO and optional CPL error reporting
* Revision 1.43 2003/12/01 16:20:08 warmerda
* be careful of zero vertex shapes
* Revision 1.42 2003/12/01 14:58:27 warmerda
* added degenerate object check in SHPRewindObject()
I have re-applied
http://bugzilla.remotesensing.org/show_bug.cgi?id=809
Please report any issues.
