[GRASS-dev] Shapelib update?
we are using an older copy of shapelib in GRASS (circa 2008). The
changelog differences of
lib/external/shapelib/dbfopen.c
look like this:
* $Log: dbfopen.c,v $
* Revision 1.88 2011-05-13 17:35:17 fwarmerdam
* added DBFReorderFields() and DBFAlterFields() functions (from Even)
* Revision 1.87 2011-05-07 22:41:02 fwarmerdam
* ensure pending record is flushed when adding a native field (GDAL #4073)
* Revision 1.86 2011-04-17 15:15:29 fwarmerdam
* Removed unused variable.
* Revision 1.85 2010-12-06 16:09:34 fwarmerdam
* fix buffer read overrun fetching code page (bug 2276)
* Revision 1.84 2009-10-29 19:59:48 fwarmerdam
* avoid crash on truncated header (gdal #3093)
* Revision 1.83 2008/11/12 14:28:15 fwarmerdam
* DBFCreateField() now works on files with records
* Revision 1.82 2008/11/11 17:47:09 fwarmerdam
* added DBFDeleteField() function
* Revision 1.81 2008/01/03 17:48:13 bram
* in DBFCreate, use default code page LDID/87 (= 0x57, ANSI)
* instead of LDID/3. This seems to be the same as what ESRI
* would be doing by default.
* Revision 1.80 2007/12/30 14:36:39 fwarmerdam
* avoid syntax issue with last comment.
* Revision 1.79 2007/12/30 14:35:48 fwarmerdam
* Avoid char* / unsigned char* warnings.
* Revision 1.78 2007/12/18 18:28:07 bram
* - create hook for client specific atof (bugzilla ticket 1615)
* - check for NULL handle before closing cpCPG file, and close after reading.
* Revision 1.77 2007/12/15 20:25:21 bram
* dbfopen.c now reads the Code Page information from the DBF file, and exports
* this information as a string through the DBFGetCodePage function. This is
* either the number from the LDID header field ("LDID/<number>") or as the
* content of an accompanying .CPG file. When creating a DBF file, the code can
* be set using DBFCreateEx.
* Revision 1.76 2007/12/12 22:21:32 bram
* DBFClose: check for NULL psDBF handle before trying to close it.
* Revision 1.75 2007/12/06 13:58:19 fwarmerdam
* make sure file offset calculations are done in as SAOffset
The shpopen.c differences are:
* $Log: shpopen.c,v $
* Revision 1.68 2010-08-27 23:42:52 fwarmerdam
* add SHPAPI_CALL attribute in code
* Revision 1.67 2010-07-01 08:15:48 fwarmerdam
* do not error out on an object with zero vertices
* Revision 1.66 2010-07-01 07:58:57 fwarmerdam
* minor cleanup of error handling
* Revision 1.65 2010-07-01 07:27:13 fwarmerdam
* white space formatting adjustments
* Revision 1.64 2010-01-28 11:34:34 fwarmerdam
* handle the shape file length limits more gracefully (#3236)
* Revision 1.63 2010-01-28 04:04:40 fwarmerdam
* improve numerical accuracy of SHPRewind() algs (gdal #3363)
* Revision 1.62 2010-01-17 05:34:13 fwarmerdam
* Remove asserts on x/y being null (#2148).
* Revision 1.61 2010-01-16 05:07:42 fwarmerdam
* allow 0/nulls in shpcreateobject (#2148)
* Revision 1.60 2009-09-17 20:50:02 bram
* on Win32, define snprintf as alias to _snprintf
How to deal with that? Which backports should be avoided?
