Greetings
I’m developing a C module in GRASS 6.4 and I have a couple of questions. Mainly, I have developed a lib (libmaximizemin) that is used by my model (or it should be). What I wanted to know is:
1- In which folder shall i place my *.so file? in GRASS/Lib ?
2- in my module makefile, in LIBES can I had my lib (e.g. -maximimizemin)
3- TO be used by my module, do I need anuything else?
Thanks
PEdro
Pedro Roma wrote:
I'm developing a C module in GRASS 6.4 and I have a couple of questions.
If the library is only going to be used by one module, there isn't
much point in making it a shared library.
If it's going to be used by multiple modules, you should add
appropriate *_LIBNAME, *LIB and *DEP variables to Grass.make.in. The
Makefile for the library should follow the same structure as for any
other library.
