Hamish wrote:
Glynn wrote:
> bin/nviz
it's really just a one line wrapper around:
exec "$GISBASE/etc/nviz2.2/nviz" -f "$GISBASE/etc/nviz2.2/scripts/nviz2.2_script" ${1+"$@"}
which doesn't need to be a shell script.
this doesn't currently work for WinGrass + wxGUI* in 6.4/5, so a great
candidate for replacement.
On Windows, visualization/nviz/scripts/nviz.bat should be installed in
$GISBASE/bin, containing:
@"%GISBASE%\etc\nviz2.2\nviz.exe" -f "%GISBASE%\etc\nviz2.2\scripts\nviz2.2_script" %*
This should work, so long as the command is invoked with shell=True
(if shell=False, only .exe files can be executed). The grass.script
module defines versions of Popen() and call() which will do this
automatically for win32.
> The remaining question is whether d.path.sh ... scripts should
> be converted to Python or removed. I don't think that d.path.sh
> works with the GUI.
it was written specifically as a component of the tcltk GUI and AFAIK
works with that. d.path should probably be written into the python
GUI as its own tool-button, which would make d.path.sh redundant in
GRASS 7.
Unless it works with the wxPython GUI, it's already redundant, as
gis.m doesn't exist in 7.0.
The script simply calls d.vect followed by d.path. None of the
display-related environment variables are changed within the script,
so it won't work with direct rendering unless GRASS_PNG_READ=TRUE
(and, AFAIK, neither GUI does this).
Yep; gmmenu.tcl has:
{command {[G_msg "Display shortest route"]} {} "d.path: Display shortest route along network between 2 nodes (visualization only)" {} -command {
unset env(GRASS_RENDER_IMMEDIATE)
guarantee_xmon
spawn d.path.sh -b --ui
set env(GRASS_RENDER_IMMEDIATE) "TRUE"}}
So it won't work in 7.0 (note that 7.0's d.path doesn't support
selecting vectors with the mouse).
Removed in r39802.
