On Nov 25, 2009, at 10:27 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Thu, 26 Nov 2009 01:25:48 +0000
Subject: Re: [GRASS-dev] Shell scripts
To: Markus Neteler <neteler@osgeo.org>
Cc: grass-dev@lists.osgeo.org
Message-ID: <19213.55580.942903.873211@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-asciiMarkus Neteler wrote:
The remaining question is whether d.path.sh and the p.* scripts should
be converted to Python or removed. I don't think that d.path.sh works
with the GUI. The p.* scripts appear to be an attempt to implement
d.mon-like behaviour for the GUI, but I don't know whether this is
functional.The p.* scripts are semi-functional and should be rewritten to Python.
Not having d.mon/d.rast/d.vect/d.zoom commands is for me, Helena, others
the obstacle to not use GRASS 7 as primary version.
Since the needed (wx)GUI pieces are there, I still hope that someone skilled
is rewriting it in Python. For us it is essential to continue with command line
in GRASS 7.d.rast and d.vect haven't gone anywhere.
If you want to be able to control the GUI from the command line, that
should be dealt with as an infrastructure issue, not by creating
wrappers around individual commands.I can deal with the display/driver libraries, and with generic Python
IPC, but some of it will need the involvement of someone who
understands the GUI.
Winter break is near and I'll be laid up for a week. So I might be able to help.
Controlling the GUI from the command line is a contradiction in interface terms. Perhaps you really mean displaying a map from the command line?
If you don't want to use a mouse, there isn't much point in trying to work with the wxGUI map display canvas as it is--with all of its buttons and menus and a lot of other functionality built in. It's not impossible to break into it, but it is not easy either--which is why the p.* scripts remain non- or only semi-functional. Also, I suspect that command-line only display will be important primarily for users of Linux. So it seems like a better solution is to have a reasonably easy command line way to composite maps and display them (perhaps in pnm or png format) in a Linux-based viewer.
Glynn has mentioned the possibility of this and most of the tools already exist. Probably a python script could be created to 1) allow a user to specify a list of vector and raster maps to overlay, 2) set the output file grass variable and recursively cycle through d.vect and d.rast, 3) run the pnm files through g.pnmcomp to composite them, and 4) display the composited map in a Linux viewer utility of some sort. d.out.file might be useful as a model to get this started. If someone wants to attempt this, I'm happy to offer advice on the Python coding.
Another option could be a simplified interface to ps.map, enter maps only or maps and a couple of overlay options like a scale and north arrow, and use ps.map to do the compositing. Then display the result in a ps viewer. These could also be combined in a Python script. There used to be a TclTk script for most of this. This might produce higher quality visualization and has the added benefit of simultaneously producing high quality print files.
Michael
