Dear developers,
would you consider as important a renaming of a map, such that it should
be recorded in its history?
After renaming,
- a vector map, it's likely possible to trace back its origin from its
history (v.info -h)
- a raster map, that has been created with `r.mapcalc`, for example, there
is no way to tell where it comes from -- other than the command history
or guessing from the expression used that is recorded in its history.
If yes, should I file a ticket?
Thank you, Nikos
