he is the simple incomplete version of auto-completion for GRASS bash
command line.
Implemented only of two commands -- d.rast and d.vect -- and works
only in the case with single parameter (d.vect mapname). It completes
the name of raster/vector map (for all mapsets as returned by
g.mlist).
How to test it: in the GRASS command line run "source
bash_completion.sh". Type "d.rast " and press TAB.
I don't know what should be auto-completed; how to deal with the
number of GRASS commands; if/how to handle parameters; what are
side-effects; how it works on various systems/shells; and how to
integrated into GRASS. The question which I tried to answer is: Is
that possible?
command line.
Thanks for the attempt Vaclav. This would be a POWER-feature
g.mlist).
I think it would be a great time-saver if it would be possible to
auto-complete existing map (file)names for parameters like "input=",
"map=" and why not (sub-)group names (think of i.group group=...) and
color rules (think of r.colors map=... color=...).
how to deal with the number of GRASS commands; if/how to handle parameters;
what are side-effects; how it works on various systems/shells; and how to
that possible?
command line.
g.mlist).
that possible?
You might want to look at this old implementation:
Hi, I didn't. So it was even working some day. It might be useful if
somebody (not sure if me) will actually write the general completion.
However, it is for g5, bash 2 (I have 4) and it is written in perl.
For g7 it should be probably in Python. While looking to the code, I'm
afraid of various shells differences. Finally, there is
--interface-description (with the parameter type) which would help to
build the completion files (not there is some parsing and guessing).
This part might be even easier than it was for 5.
Nevertheless, it seems that there was and is an interest in this.
