[GRASS-dev] single vs. multiple sqlite db files [was v.db.calc]
Moritz wrote:
I would plead for solid modules allowing to export and
import GRASS data between GRASS installations (e.g.
something like the r.pack/r.unpack modules). IMHO, moving
around data should not depend on the location of the
database or the choice of database backend (i.e. how do you
handle above export with a PostgreSQL backend ?). We need to
povide a mecanism which allows users to do that while
respecting the unwritten law that they should not have to do
anything at all inside their GISDBASE.
it should not be hard to extract a single map's data from a DB as part
of any v.pack/v.unpack script. Just temporarily change the DB settings
before running 'g.copy vect=$INPUT,$TEMP_MAP', then restore the DB settings
to their original. Probably for PostgreSQL etc you want to temporarily
change to sqlite anyway as part of the packing procedure to ensure that
the data is portable? (???)
just an idea, but for the decision I think the v.pack reason should not
be a blocker.
Hamish
