[GRASS-dev] SIngle-Window GUI not working on Ubuntu 22.04
Dear devs,
I just upgraded to the latest Ubuntu LT (22.04) and recompiled GRASS GIS. Unfortunately, the singe-window GUI does not work anymore.
This problem was reported as a bug earlier, see https://github.com/OSGeo/grass/issues/2466, but I can’t make the proposed solutions work. I wonder if this is on the radar, and if there are directions for a easier and more permanent solution, so we can enjoy this great new feature on Ubuntu as well.
Paulo
Hi Paulo,
if you are getting the same problem, you should install the latest wxPython:
pip install -U -f https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-22.04/ wxPython
That should fix it. The wxPython in packages may be old and not patched, only 4.2.0 (released 2 weeks ago) has the fixes.
Anna
On Wed, Aug 17, 2022 at 9:05 AM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Dear devs,
Paulo
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Tue, Aug 23, 2022 at 12:07 PM Anna Petrášová <kratochanna@gmail.com> wrote:
Hi Paulo,
Brilliant, works like a charm, I don’t even need to recompile grass. Thanks Anna!
Anna
Dear devs,
Paulo
