[GRASS-dev] [siteadmin-Bugs][560] SQL dump of GRASS trackers request
XML export from GForge now works:
---------- Forwarded message ----------
Date: Mon, Apr 7, 2008 at 4:37 PM
Subject: [siteadmin-Bugs][560] SQL dump of GRASS trackers request
To: noreply@wald.intevation.org
Bugs item #560, was opened at 2007-12-08 14:47
Status: Open
Priority: 4
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Sascha Wilde (wilde)
Summary: SQL dump of GRASS trackers request
Comment By: Markus Neteler (markusn)
Date: 2008-04-07 16:37
Message:
Sascha fixed XML export of GForge today (thanks!):
http://wald.intevation.org/export/tracker.php?group_id=21&atid=204
Now we need to process this XML to generate something useful for trac.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=162&aid=560&group_id=1
Markus Neteler pisze:
I'm sorry but I don't have much spare time until mid-summer or so (work work work). I won't be able to help much until then. Please anybody willing to port existing GForge tickets to Trac do it.
Maciek
> trac.
fyi, last week I started on writing a HTML scraper for the old RT bug
tracking system. that could be adapted to create & fill the same xml
fields as the GForge export. I could put the work in progress into the
addons svn if there is interest-- it needs a lot of work, and I wouldn't
mind help as my regex is quite poor.
the idea is to loop trough all non-killed bug reports, archive closed
reports directly as a big concatenated HTML file, and for open
bugs/wishes both archive the html content and parse it to XML for
reinsertion into the trac system as needed.
there needs to be a lot of spam cleanup, and it probably needs to be done
manually once the dump is finished. :frowning:
for the Gforge system there are few enough of those that porting all of
them to the trac system would be ok I think.
if we could finish+close the last 3 gforge doc bugs, it would only be
code bugs and patches left open there.
Hamish
      ____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
