[GRASS-dev] slow access to osgeo svn
Hello,
Access to the OSGEO svn server is extremely slow for me. Do others have the same problem ? I can connect to http://www.osgeo.org/ and http://trac.osgeo.org/grass/browser no problem.
Moritz
2007/12/14, Moritz Lennert <mlennert@club.worldonline.be>:
I can confirm that sometimes OSGeo services are strangely slow... For
me -- right now, svn up works perfectly, but to load
http://trac.osgeo.org/grass/wiki is taking minutes...
Martin
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Martin Landa escribió:
I can also confirm that. I have just committed a single file (170 KB) and it took over three minutes, when it usually took only a few seconds with cvs.
Carlos
Folks,
I haven't seen any performance problems today. It does generally take me a
long time to do svn commits, but I'm on a high latency link. Trac and
svn checkouts seem fast for me. I logged into the server and it does not
seem to have undue load though we did have a problem with the server being
taken down a day or two ago by some strange load spike.
I'm rather at a loss, and tend to attribute the problem to strange
internet packet routing problems. Perhaps Peer1, our ISP is not well
peered with some parts of Europe?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
here another suggestion how to report:
On Dec 14, 2007 4:32 PM, Frank Warmerdam wrote:
Markus,
If folks can report when they are having problems in #osgeo we can attempt
to monitor the state of the server, and/or have folks try similar
operations
from other locations to try and work out a pattern.
You can easily reach IRC with zero installation through this Web client:
http://irc.telascience.org/cgi-bin/irc.cgi
- select reasonable nick name
- select #osgeo
Then they can check immediately what's going on.
View this message in context: http://www.nabble.com/slow-access-to-osgeo-svn-tp14333802p14338753.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
- select #osgeo
A lot of irc protocols are blocked or forbidden behind corporate/government firewalls for some of us (big brother is always watching), so that isn't always an option.
~ Eric.
>- select #osgeo
>Markus
Right.
BTW: OSGeo-SAC just identified one (the?) problem: Sometimes
the CIA service (IRC bot, [1]) is hanging, so SVN waits to
receive CIA timeout. Apparently we can only ask to switch
off CIA notification but I dunno if it is what we want.
[1] http://cia.vc/stats/project/GRASS
