I have a small correction for the manual page of the r.gradient addon. In the examples, the parameter 'values' is used. This should be 'range' I assume. Luca, if you want me to correct his, I can, otherwise, see attached a patch file.
On Mon, Jan 30, 2017 at 11:20 AM, Paulo van Breugel
a patch file.
a patch file.
a patch file.
