[GRASS-dev] [SoC] Parallelization of Raster and Vector modules
On Thu, Apr 1, 2010 at 3:24 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Jordan Neumeyer wrote:
Just kind of my thought process about how I would try to go about
parallelizing a module.
The main issue with parallelising raster input is that the library
keeps a copy of the current row’s data, so that consecutive reads of
the same row (as happen when upsampling) don’t re-read the data.
For concurrent access to a single map, you would need to either keep
one row per thread, or abandon caching. Also, you would need to use
pread() rather than fseek()+read().
It sounds like you’re talking about parallelism in I/O from a file or
database. Neither of which is my intent or goal for this project. I will
parallelize things after they have already been read into memory, and tasks
are processor intensive. I wouldn’t want parallelize any I/O, but if I were
to optimize I/O. I would make all operations I/O asynchronous, which is can
mimic parallelism in a sense. Queuing up the chunks of data and then
processing them as resources become available.
Most GRASS raster modules process data row-by-row, rather than reading
entire maps into memory. Reading maps into memory is frowned upon, as
GRASS is regularly used with maps which are too large to fit into
memory. Where the algorithm cannot operate row-by-row, use of a tile
cache is the next best alternative; see e.g. r.proj.seg (renamed to
r.proj in 7.0).
That makes more sense. So a row is like chunk from the map data? Kind of like the first row of pixels from an image. So from the first pixel to width of image is one row, then width plus one starts the next, and so on and so forth. How large are the rows generally?
Holding an entire map in memory is only considered acceptable if the
algorithm is inherently so slow that processing a gigabyte-sized map
simply wouldn’t be feasible, or the access pattern is such that even a
tile-cache approach isn’t feasible.
In general, GRASS should be able to process multi-gigabyte maps even
on 32-bit systems, and work on multi-user systems where a process
cannot assume that it can use a significant proportion of the system’s
total physical memory.
Which is good. I didn’t realize how big the data set could be. What’s biggest map you’ve seen?
It’s more straightfoward to read multiple maps concurrently. In 7.0,
this case should be thread-safe.
Alternatively, you could have one thread for reading, one for writing,
and multiple worker threads for the actual processing. However, unless
the processing is complex, I/O will be the bottleneck.
I/O is generally a bottleneck anyway. Something always tends to be waiting
on another.
When I refer to I/O, I’m referring not just to read() and write(), but
also the (de)compression, conversion and resampling, i.e. everything
performed by the get/put-row functions. For many GRASS modules, this
takes more time than the actual processing.
I can see why, especially for big maps since it’s doing that row-by-row.
So when a GRASS module loads a map the basic algorithm looks something like:
  1. Read row
  2. get-row function does necessary preprocessing
  3. row is cached or held in memory. Does the caching take place after
  4. row is processed
  5. Display/write process ? (Or is this after a couple iterations, all of them?)
  6. repeat (1)
Would it be beneficial/practical to parallelize some of the preprocessing like conversion and resampling before the caching occurs?
Finally, the thread title refers to libraries. Very little processing
occurs in the libraries; most of it is in the individual modules. So
there isn’t much scope for “parallelising” the libraries. The main
issue for library functions is to ensure that they are thread-safe.
Most of the necessary work for the raster library has been done in
7.0.
I was trying to refer to all of the raster modules as a whole, but library is just what the modules share. I’ve changed the title from Parallelization of Raster and Vector libraries to Parallelization of Raster and Vector modules.
Would I be working on GRASS 6.x or 7.x? Is there a minimum compiler version when using GCC/MingW? Just curious because openMP tasks are only supported on GCC >= 4.2. Which may or not be useful, but can be a valuable tool when you don’t know how much data or how many “tasks” you have. Like processing a linked-list or binary trees.
~Jordan
> r.proj in 7.0).
The width is determined by the current region. Input data is cropped,
padded with nulls and/or (nearest-neighbour) resampled to match the
current region.
The primary functions for reading raster data are:
6.x (and earlier):
  int G_get_raster_row(int fd, void *buf, int row, RASTER_MAP_TYPE type);
  int G_get_c_raster_row(int fd, CELL *buf, int row);
  int G_get_f_raster_row(int fd, FCELL *buf, int row);
  int G_get_d_raster_row(int fd, DCELL *buf, int row);
7.0:
  void Rast_get_row(int fd, void *buf, int row, RASTER_MAP_TYPE type);
  void Rast_get_c_row(int fd, CELL *buf, int row);
  void Rast_get_f_row(int fd, FCELL *buf, int row);
  void Rast_get_d_row(int fd, DCELL *buf, int row);
The buffer must contain space for G_window_cols() (Rast_window_cols() in
7.0) values. "row" must be non-negative and less than G_window_rows()
(Rast_window_rows() in 7.0); rows can be read in any order.
For writing, the functions are:
6.x (and earlier):
  int G_put_raster_row(int fd, const void *buf, RASTER_MAP_TYPE type);
  int G_put_c_raster_row(int fd, const CELL *buf);
  int G_put_f_raster_row(int fd, const FCELL *buf);
  int G_put_d_raster_row(int fd, const DCELL *buf);
7.0:
  void Rast_put_row(int fd, const void *buf, RASTER_MAP_TYPE type);
  void Rast_put_c_row(int fd, const CELL *buf);
  void Rast_put_f_row(int fd, const FCELL *buf);
  void Rast_put_d_row(int fd, const DCELL *buf);
Exactly G_window_rows()/Rast_window_rows() rows must be written,
sequentially and top-to-bottom, hence the lack of a "row" parameter.
Where possible, modules keep as few rows in memory as possible. E.g.
r.series keeps a single row from each input map and a single row of
output data. r.resamp.interp keeps 1 (nearest), 2 (bilinear), or 4
(bicubic) rows of input and one row of output. r.neighbors keeps as
many map rows as there are rows in the neighbourhood window (i.e. a
sliding window).
The core of a simple raster module might look something like:
  rows = G_window_rows();
  cols = G_window_cols();
  for (row = 0; row < rows; row++ {
    G_get_d_raster_row(infd, inbuf, row);
    for (col = 0; col < cols; col++ {
    G_put_d_raster_row(outfd, outbuf);
> simply wouldn't be feasible, or the access pattern is such that even a
> tile-cache approach isn't feasible.
> cannot assume that it can use a significant proportion of the system's
Which is good. I didn't realize how big the data set could be. What's
biggest map you've seen?
I'm a programmer who works on GRASS mainly out of interest, so I don't
have to actually deal with large datasets. But 10000x10000 doesn't
seem to be that uncommon here. The 2GiB limit on the (compressed) data
used to be a common problem until we added large file support. Using
r.series with 365 input maps isn't uncommon.
> When I refer to I/O, I'm referring not just to read() and write(), but
I can see why, especially for big maps since it's doing that row-by-row.
1) Read row
2) get-row function does necessary preprocessing
3) row is cached or held in memory. Does the caching take place after
4) row is processed
5) Display/write process ? (Or is this after a couple iterations, all of
them?)
5) repeat (1)
Reading involves:
1. read()
2. Decompress (RLE or zlib)
3. Convert from portable representation to internal representation
(e.g. byte swapping, sign-bit to two's complement).
4. Crop, pad, resample
5. Embed nulls
6. Embed mask
7. Reclass
The result of step 3 is cached; a subsequent read of the same underlying
row will repeat steps 4-7 (when upsampling, consecutive region rows will
often correspond to the same underlying row in the input file).
Writing is simpler, and only involves (the reverse of) steps 1-3 and
5.
7.x.
you don't know how much data or how many "tasks" you have. Like processing a
We try to support any C89-conformant compiler; extensions shouldn't be
used without a fallback (e.g. we use __attribute__ but define it to an
empty macro if the compiler isn't gcc). Code should compile and run on
all common platforms (Linux, Windows, Mac OSX, and any reasonably
modern Unix) wherever possible.
On Sun, Apr 4, 2010 at 3:22 AM, Jordan Neumeyer
Our provincial DEM is a 3.5GB Geotiff which is of 48800x58000 size.
Another file which I recently had to import was a 4GB Geotiff with
21550 bands. Finally, in remote sensing, you can quickly generate
quickly files in the multi-GB range.
Yes indeed, only to process simple equations on multi-Gb images takes some time.
grass-dev mailing list
grass-dev@lists.osgeo.org
Yann Chemin
Senior Spatial Hydrologist
www.csu.edu.au/research/icwater
M +61-4-3740 7019
Jordan,
I've dealt with ERDAS Imagine files larger than 10 GB on a regular basis. I have occasionally tried to reproject and merge all of the 1 m NAIP imagery tiles for North Carolina into 1 BigTIFF > 500GB with gdal. Any parallelizaion work for open source geospatial tools would be welcome :-).
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
-----grass-dev-bounces@lists.osgeo.org wrote: -----
To: Jordan Neumeyer <jordan.neumeyer@mines.sdsmt.edu>
Sent by: grass-dev-bounces@lists.osgeo.org
Date: 04/05/2010 04:06AM
cc: GRASS developers list <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] [SoC] Parallelization of Raster and Vector modules
[http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)
Thanks guys for putting that into perspective.
On Mon, Apr 5, 2010 at 6:38 PM, <Doug_Newcomb@fws.gov> wrote:
Jordan,
So you “tried” to do that? Does that mean you failed or is the system still processing it? :stuck_out_tongue: I kid, but that is a very large file… it’s bigger than my current desktop’s hard drive.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 [doug_newcomb@fws.gov](mailto:doug_newcomb@fws.gov)
-----[grass-dev-bounces@lists.osgeo.org](mailto:grass-dev-bounces@lists.osgeo.org) wrote: -----
To: Jordan Neumeyer <[jordan.neumeyer@mines.sdsmt.edu](mailto:jordan.neumeyer@mines.sdsmt.edu)>
From: Markus Neteler <[neteler@osgeo.org](mailto:neteler@osgeo.org)>
Sent by: [grass-dev-bounces@lists.osgeo.org](mailto:grass-dev-bounces@lists.osgeo.org)
cc: GRASS developers list <[grass-dev@lists.osgeo.org](mailto:grass-dev@lists.osgeo.org)>
<[jordan.neumeyer@mines.sdsmt.edu](mailto:jordan.neumeyer@mines.sdsmt.edu)> wrote:
~Jordan
>>Jordan,
>>I've dealt with ERDAS Imagine files larger than 10 GB on a regular basis. I have occasionally tried to >>reproject and merge all of the 1 m NAIP imagery tiles for North Carolina into 1 BigTIFF > 500GB with gdal. >> Any parallelizaion work for open source geospatial tools would be welcome :-).
Jordan,
It would be a shame to leave those multicore 64 bit processors with multi-terabyte hard drives with nothing to challange them. Just think of me as part of the hardware entertainment committee. :slight_smile:
The process ran overnight and finished, I just have not gotten to phase 2 of that particular project, chopping the resulting image into overlapping DOQQ - size images. I was going to go back and change the projection method slightly, hopefully to make it more accurate. If you’re looking for big images to play with, go to http://datagateway.nrcs.usda.gov/ and select a naip county mosaic of imagery. The mosaic comes as a MrSid format file, but once you uncompress it ( I suggest using gdal’s nearblack utility ) to ERDAS Imagine format, the resulting image will probably be in the multi-gigbyte range per county.
Doug
Doug Newcomb
USFWS
Raleigh, NC
04/08/2010 01:09 AM
To
cc
Subject
Doug
Doug Newcomb
USFWS
Raleigh, NC
~Jordan
Hello,
was wondering if the actual raster library API could be extended to
read/write a given n contiguous number of lines in a buffer instead of
a single one? This maybe of help for parallelization...
Yann
On 4 April 2010 11:22, Jordan Neumeyer <jordan.neumeyer@mines.sdsmt.edu> wrote:
> > keeps a copy of the current row's data, so that consecutive reads of
> > the same row (as happen when upsampling) don't re-read the data.
> It sounds like you're talking about parallelism in I/O from a file or
> tasks
> are processor intensive. I wouldn't want parallelize any I/O, but if I
> were
> can
r.proj in 7.0).
> > It's more straightfoward to read multiple maps concurrently. In 7.0,
> waiting
> on another.
1) Read row
4) row is processed
them?)
5) repeat (1)
there isn't much scope for "parallelising" the libraries. The main
7.0.
is just what the modules share. I've changed the title from Parallelization
modules.
~Jordan
Yann Chemin
M +61-4-3740 7019
Jordan,
Good, they need to be kept busy. Don’t want to bore them. :wink:
Well that’s good. It only took overnight for 500 GB? That doesn’t sound too bad. I’m not looking for huge maps, but some decent-sized samples would be good for testing. Thanks for the resource I’ll look into it if I need some samples for testing. The warning at the bottom the site is a bit nerving though… I’m not a government official.
Doug
Doug Newcomb
USFWS
Raleigh, NC
04/08/2010 01:09 AM
To
cc
Subject
Doug
Doug Newcomb
USFWS
Raleigh, NC
~Jordan
