1. What did you get done this week?
a. With my mentor’s help, resolved the problem with the .o files not linking. Accomplishing this included adding the Makefile to the git repo. (It was not added originally because I inadvertently had Makefile listed in .gitignore, so I also removed that. Link to Commit)
b. Refactored function basicReaderWriter from dwelling in main.cpp to being found as a static function in the pipelinejson class. Commit
c. In consultation with my mentor (Vashek) determined to proceed by creating a new class, PdalVectorMapWriter, which will inherit from PDAL’s Writer class. This will allow the GRASS Vector Map writer to be included as an end point in a json pipeline when invoked from GRASS. Implementing this has been started but not completed. This follows on to last weeks item 2a: “get a basic, no-frills conversion from .las to GRASS to work like basic .las to .txt is now working.” Commit to add hpp and cpp files Commit refactoring existing files
2. What do you plan on doing next week?
a. Complete last week’s item 2a, get a basic, no-frills conversion from .las to GRASS Vector Map to work.
b. Begin work on a basic conversion from .las to GRASS Raster. (r.in.pdal)
c. Complete last week’s item 2c, Create unit tests for item 2a.
d. Begin work adding features to v.in.pdal.
3. Are you blocked on anything?
No.
