Hi All
I have two propositions on r.neighbour:
1) add existing method "range" to existing methods of r.neighbors
it is only only one line:
{c_max, NULL, NO_CATS, 1, 0, "maximum", "highest value"},
+ {c_range, NULL, NO_CATS, 1, 0, "range", "maximum - minimum"},
{c_stddev, w_stddev, NO_CATS, 0, 1, "stddev", "standard deviation"},
reason:
parameter "range" can be calculated as max-min, but it require three calculation: r.neigbour twice, and r.mapcalc one. For large maps and large window it takes lot of time. That parameter is broadly used in geomorphology as "relief energy" equivalent and as far as I know is frequently calculated (of course not only in GRASS GIS)
2) add new method "percentile" and add it to existing method of r.neighbours
I attached code as percentile2.c. For testing purpose I added it to directory r.neighbors, and add one line into methods:
{c_perc, NULL, NO_CATS, 0, 0, "percentile", "percentile of center value"},
reason:
method "percentile" returns the percentile of the central cell. If it is max cell in the neighbor it returns 1 in smallest it returns 1/cell_count.
That parameter can be use in geomorphology to determine valleys (usually values lower than first quartile: 0.25) and ridges (usually values grater than 3th quartile 0.75). I send it to GRASS DEV Because I'd like to share this code with other grass users, and the easiest way is to add this parameter to GRASS is expand r.neighbors (creating ADD_ON r.neigbors fork or completely new module only for one parameter is nonsense).
regards
Jarek Jasiewicz
(attachments)
percentile2.c (674 Bytes)
