[GRASS-dev] some question about GRASS vectors
Hi devs,
I'm working on a QGIS plugin to check the differences between an input
shapefile and the resulting GRASS vector. I have some doubts:
- a line with only a point is a valid line? I was thinking it should
not be valid but GRASS doesn't return any error
- is it correct that attributes for multipolygon or polygon with self
intersection (so GRASS creates two different areas) are not imported?
I attach three different GeoJSON that I used for my tests
Thanks in advance
ciao
Luca
www.lucadelu.org
(attachments)
caramella.json (229 Bytes)
multipolygon.json (261 Bytes)
wrong_line.json (153 Bytes)
On 18/05/16 16:37, Luca Delucchi wrote:
Hi devs,
No error at what operation ?
I can import with v.in.ogr, just as I can open it with QGIS.
But, yes, GRASS does import a one-point line. You can confirm this with
echo "L 1 1
   100.0 0.0
   1 1" | v.in.ascii in=- out=line format=standard -n
Whether this is good or bad is open to discussion.
The programmer's manual states:
line: a directed sequence of connected vertices with two endpoints called nodes (2D or 3D) - GV_LINE
But it doesn't say that the two nodes can't be identical. AFAIU, the vector format is essentially points stored in the coor file with additional information about what type of feature each point belongs to. GRASS doesn't really care about how many points are there.
You can even import a boundary with only one point. You will get a warning at topology build time that the boundary is incorrect, but this is only a warning, not an error...
No. Importing your two files with v.in.ogr I get two polygons, both with the same category value and this points to an attribute table that contains the attribute.
Moritz
On Thu, May 19, 2016 at 4:48 PM, Moritz Lennert
Hi devs,
echo "L 1 1
  100.0 0.0
A line or boundary consisting of only one point does not make sense
but it is technically possible. They can be removed with v.clean
tool=rmline
attribute.
That is correct. In OGR, a multipolygon is a single geometry object,
and all polygons in that object have the same attributes. This feature
is preserved when importing into GRASS: all objects in the same
multi-geometry object have the same attributes.
From a topological perspective, the split of the self-intersection
into two areas is also correct.
Markus M
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
