[GRASS-dev] Some simple questions about coding style.
I was looking at g.copy source and now I have some simple questions:
1) Is it safe to pass int to G_calloc(), as it expects size_t?
2) Is it safe to G_malloc() fixed amount for parser's option
description? (opt->description)
3) Why G_warning isn't a viod function? It always returns 0 and none
of GRASS modules performs check for it's return value.
Thanks for answers to GRASS C guru's.
Maris.
(attachments)
manage.patch (4.62 KB)
Yes.
Provided that you don't need any more than that. In the case of
g.copy, it should probably either use G_asprintf() or sprintf() into
an oversized local array then make a copy with G_store().
Much of GRASS uses pre-ANSI conventions where functions always return
a value. We should probably make an effort to fix this stuff once 6.3
is out of the way.
