[GRASS-dev] Source code link in Addons
Hi devs,
a power user ask me to implement source code link also in Addons, so I
looked a little bit to the code and it seems it should work already.
During addon compilation Script.make is called, inside this there is
Html.make, this is calling mkhtml.py that contains the code to add
"Source code", so I don't understand why this is not added (with wrong
url) to the HTML file?
Am I missing anything? otherwise I will check a little bit deeper in
the actual code...
ciao
Luca
www.lucadelu.org
Hi Luca,
On Wed, Dec 14, 2016 at 3:39 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi devs,
I think it all works. The point is that the Addons on the Web site are
compiled against V7.0.svn while only V7.2.svn comes with the new
source code/history link.
As soon as we enable building the addons against 7.2. it will be included.
In local 7.2 installations, with g.extension, the manual of addons
contains the desired links (try with g.manual someaddon).
So I think it is all working, just not yet visible on the Web site.
Hi :slight_smile:
I checked what Markus says, and yes the links appear in addons if I
call g.manual some-addon from 72 or 73, but I am not redirected to the
source code. Instead, I get the following:
Trac Error
No node grass/trunk/home/veroandreo/tmp/grass7-veroandreo-18093/tmppTzxLm/t.rast.out.xyz
at revision 70080
Do you get the same or is something in my PC only?
Thanks much!
Vero
2016-12-14 22:23 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
Hi Luca,
Hi devs,
grass-dev mailing list
grass-dev@lists.osgeo.org
2016-12-15 9:01 GMT+01:00 Veronica Andreo <veroandreo@gmail.com>:
Trac Error
at revision 70080
you are right, links are broken. Please report on trac. Thanks, Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
ยทยทยท
2016-12-15 22:08 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
Trac Error
at revision 70080
Done in #3224 (https://trac.osgeo.org/grass/ticket/3224)
Thanks :slight_smile:
Vero
