[GRASS-dev] spam in bug tracker
On Wednesday 20 September 2006 11:39, Maciej Sieczka wrote:
Eric has found that spam is being added to existing BT tickets.
See eg. at the bottom of
http://intevation.de/rt/webrt?serial_num=1107
http://intevation.de/rt/webrt?serial_num=2904
Is there anything we can do about it?
unfortunately, our RT tracker has been flooded by a SPAM
attack that used HTTP (not mail).
We switched off opportunity to add comments as anonymous.
(we had to patch rt for this at its configuration does only allow to
switch of new bugs send by anonymous).
Another good reason to the new bug tracker.
There, it is also only allowed to comment/submit if you are
a registered user. But unlike for rt, there you can
create a user account on your own easily.
Best
  Jan
Jan-Oliver Wagner: www.intevation.de/~jan | GISpatcher: www.gispatcher.de
Kolab Konsortium : www.kolab-konsortium.de | Thuban : thuban.intevation.org
Intevation GmbH : www.intevation.de | Kolab : www.kolab.org
FreeGIS : www.freegis.org | GAV : www.grass-verein.de
Thanks for the quick service Jan, and thanks to Maciek and Eric for all
their efforts too. It's a frustrating business.
I guess the sooner we migrate to the new bug tracker the better then.
After that we can start on CVS->SVN and OSGeo migrations :wink:
Hamish
Hi
I fully second Hamish that we should keep bug reporting possible for
anonymous users. I prefer to have to deal with spam from time to time
(yuck!) than to miss a usefull message.
But I hope that the new bugtracker that Grass some-day will have, will
provide a possibility to delete or modify single past records in the
given ticket, not only to kill the whole bogus ticket. Anybody knows if
Trac has such thing?
Maciek
Maciej Sieczka wrote on 09/28/2006 02:52 PM:
Hi
I think that this is the key - being able to delete individual posts to
a bug
report. Given that, we could keep it open as before.
a bug
the tracker of GForge does not offer to remove comments.
Only attachments can be deleted.
I know that RoundUp allows to remove comments, but this tracker
is not integrated (yet) in GForge.
Best
  Jan
Has anybody disabled posting as guest to BT? It gives:
"You are not allowed to reply on requests as guest"
Will people be able to reply via email at least?
Maciek
As Jan-Oliver wrote earlier today (yesterday...) guest posting is blocked for the moment. See http://grass.itc.it/pipermail/grass5/2006-September/026115.html
Moritz
Maciek
grass-dev mailing list
grass-dev@grass.itc.it
True. But wiht current spam level and robot, you will need to have a
human queue before it really goes into the tracker.
The administrator can do this in request-tracker already
and manipulate the database.
> > Anybody knows if
> a bug
I do not think this is feasabl; humans cannot beat robots that fill out
webforms.
Our main reason to move to Gforge software (not the propietary software of
gforge group) is that we will have a larger user community that has the same
needs, so additions and changes will be easier to make and will be useful to
more people as well.
I suggest adding a feature request to www.gforge.org.
If somebody would want to work on this, it would be cool. :slight_smile:
Bernhard
Bernhard Reiter wrote:
> > > Anybody knows if
> > a bug
webforms.
Can we add a captcha to the form? This would only be required for
guest users.
> > > > Anybody knows if
> > > posts to a bug
> out webforms.
guest users.
An easy implementation I've seen was a simple auto-generated web page
that asked a randomly generated simple math question in english. e.g.
"What's [nine] [minus] [four]?" _________ [Submit]
We're not Hotmail or Yahoo! Mail, so I doubt we have to bother with
"spot the word in the noise" tricks. Beating a custom app from
relatively small projects like ours just isn't worth the spammer's
time (by definition they're trying to take the lazy route to success).
Hamish
Anybody knows if
posts to a bug
out webforms.
For the time being we've been able to remove all the spam BT tickets
manually.
Also considering that the spam is currently being added manually to the
existing tickets in our BT, I think we could also remove that manually,
if it was technically possible. Only that the person in charge should
be informed about each new BT modification by email (that's currently
impossible in our BT as I was told; would Gforge tracker provide such
option?). I woulnd't mind to be that person.
Only if there is nobody willing to take care of spam in BT (eg. I quit
in future) or if the amount of spam making through is beyond a few
minutes work a day, the anonymous access should be limited. Otherwise
we should keep the BT system open for anyone if possible.
Maciek
... but: we don't have an admin outside of Intevation AFAIK...
(who could also change Harmish to Hamish in RT).
I feel that GRASS folks would love to switch the BT now,
what does Intevation think? Besides the spam problem, we
basically have the missing patch management problem in RT.
Markus,
Aren't you an admin?
https://intevation.de/rt/admin-webrt?display=Modify+the+User+called&user_id=mneteler
Maciek
have, will provide a possibility to delete or modify single past
records in the given ticket, not only to kill the whole bogus
ticket.
MN:
I dunno, I always get a chuckle out of that. It reflects on how bad a C
programmer I am.
MS:
Markus,
Hey, I hadn't seen that before. After logging in as myself, I have now
changed my own name to the more common spelling.
fyi, for me it says-
Access Control
grass: Manipulate
thuban: Display
etc.
MN:
Besides the spam problem, we basically have the missing patch
Indeed.
Hamish
> > I do not think this is feasable; humans cannot beat robots that fill
> > out webforms.
> guest users.
Sure, we can. This would need to be our own implementation
as you already found out. Do not underestimate this as it is a source
for new problems.
I agree.
If you want to start coding this one,
I suggest to take the current gforge code and add it (www.gforge.org).
Bernhard
Managing Director - Owner, www.intevation.net (Free Software Company)
Germany Coordinator, fsfeurope.org (Non-Profit Org for Free Software)
www.kolab-konsortium.com (Email/Groupware Solution, Professional Service)
>>> out webforms.
manually.
This has changed. Last week we had a scripted attack on our current tracker.
We are still doing some last cleanups.
When we got more spam emails, we needed to close the ability to comment on
some issue, now we just closed the ability for a guest to add comments over
the web. :frowning:
It is possible to get a notification for each transaction for the current
tracker. I did not consider it a good compromisse so far and advised against
it. Currently you cannot remove single entries.
would Gforge tracker provide such option?).
Yes, just as does RequestTracker.
My fear is that it the situation "it takes a few minutes" will be changing
rapidly. If someone wants to make a contribution, it will not be asked too
much to have them register, though I would prefer the other solution.
Your few minutes could be spend on more worthwhile tasks in my opinion.
Bernhard
True, I have meant superuser rights on the machine.
You or Hamish can do that as far as I know.
It is fine to start using the Gforge Tracker of wald.intevation.org now
for GRASS. We need a migration policy of course.
And the decision how many project for GRASS we want to register on wald.
Should we seperate grass-windows or grass-doc or not?
My feeling is: We do not want to seperate, yet.
For phase a) we would only enter new issues in the gforge tracker
and keep the old tracker.
Also possible: If an issue is acted upon, transfer if to the tracker.
Next we need a script to transfer the 500 open issues to the new tracker.
Also there is the decision of where to archive the handled issues.
My suggestion would be to keep the request-tracker running for documentation
purposes.
Bernhard
As said before: Intevation offers the wald.intevation.org infrastructure
which is a gforge software and has SVN.
We just need to plan and execute the
I have not been following all of their decisions.
My suggestion for GRASS would be to stay on its own infrastructure
and own legal entities as GRASS is big enough to actually profit
from it.
Bernhard
I tried, I cannot...
While I am listed as admin, I don't seem to have admin
rights :slight_smile: (which is ok).
I agree.
This sounds very good to me.
purposes.
Also agreed.
