Hi developers,
I'm trying to make udig speak the same language as GRASS, but I found
one main issue, I'm not able to resolve.
GRASS and UDig use different projection definitions.
- in Grass the projection file is something like:
proj: tmerc
datum: rome40
towgs84: -225.000,-65.000,9.000
a: 6378388
es: 0.0067226700
lat_0: 0
lon_0: 9
k: 0.999600
x_0: 1500000
y_0: 0
no_defs: defined
- whereas in UDig it is WKT:
PROJCS["Monte Mario / Italy zone 1",
GEOGCS["Monte Mario",
DATUM["Monte_Mario",
SPHEROID["International 1924", 6378388.0, 297.0,
AUTHORITY["EPSG","7022"]],
AUTHORITY["EPSG","6265"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Lon", EAST],
AXIS["Lat", NORTH],
AUTHORITY["EPSG","4265"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["central_meridian", 9.0],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["scale_factor", 0.9996],
PARAMETER["false_easting", 1500000.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["x", EAST],
AXIS["y", NORTH],
AUTHORITY["EPSG","3003"]]
I'm no projection wizard, has anyone an idea about how I can go from one
to the other and back in an easy way?
Thanks for any help,
