Hi Moritz,
Thanks to your help, I now have been able to run through a number of the vector network operations. Two that don’t seem to work are v.net.steiner and v.net.spanningtree. But perhaps I am not doing it right.
Here is the setup using Highschools from the schools_wake vector and streets_wake in the sc_08 demo data set.
First I connect highschools (previously extracted from schools_wake) with the streets.
v.net --overwrite input=streets_wake@grass7vect_sqlite points=highschools@spatialtech2012 output=hs_net operation=connect alayer=1 nlayer=2 thresh=200
When I run v.net.stiener, it gives no error but doesn’t create anything either. Here is the command:
v.net.steiner input=hs_net@spatialtech2012 output=hs_steiner type=line alayer=1 nlayer=2 tcats=4,7,11,12,37,49,50,65,67,69,77,83,91,101,103,115,117,138,153,158,164,165
When I run v.net.spanningtree, I do get results, but it is a complex street network that is almost the same as the original street network. Here is the command I am using:
v.net.spanningtree --overwrite input=hs_net@spatialtech2012 output=hs_spanningtree alayer=1 nlayer=2
Any suggestions?
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
