given following workflow:
- Polygon vector A, line vector B
- Spatially select those polygone in A which are e.g. touched by some lines
in B
- open attribute table, view entries selected by step before
- update some columns of the selected entries
as this workflow is available in mostly all modern desktop GIS, I couldn't
find a smart way in GRASS GIS to do this.
any hints are welcome.
If it is not implemented, should I open an enhancement ticket because it is
a common needed workflow?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Spatial-vector-selection-by-another-vector-without-creating-a-new-vector-tp5266838.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On 17/05/16 23:21, Helmut Kudrnovsky wrote:
in B
Brainstorming:
- Create a column line_cat in vector A
- Use v.distance with dmax=0 to get upload cat value of line that crosses polygon
- v.db.update on the other column using where="line_cat is not null"
This could be wrapped up in a script...
This has been briefly mentioned as one advantage of 'virtual maps', discussed as an alternative to cat/where parameters in vector modules [1].
I agree that "on-the-fly" selection of features by others would be quite useful. I use this quite a lot in QGIS for example (e.g. through the spatial queries plugin). Although, I haven't seen an option to update a column just for selected features. I use it, for example, to calculate statistics on vector attributes only for those that are selected, etc.
Moritz
[1] https://trac.osgeo.org/grass/ticket/1798#comment:12
