Hi.
mapset user1 in spearfish_grass60data-0.2.tar.gz
has defined database in VAR file:
DB_DRIVER: dbf
DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
but dbf directory (database) does not exists. You should either
remove user1/VAR file or create user1/dbf directory.
Radim
Radim Blazek wrote on 08/10/2006 12:52 PM:
Hi.
DB_DRIVER: dbf
hi Radim,
where is this a problem (QGIS?)? The user1/dbf directory should be
autocreated
once needed. But yes, we should add it to spearfish_grass60data-0.2.tar.gz.
The database is only created if database/driver is not set in VAR.
If user sets a database manualy (as he does in user1 mapset)
it is his responsibility to create also the database.
Radim
> Hi.
> DB_DRIVER: dbf
hi Radim,
autocreated
grass-dev mailing list
grass-dev@grass.itc.it
I have added the missing dbf directory back. Thanks for pointing this out.
Markus will be putting the corrected 0.3 spearfish60 online soon.
Maciek
On Fri, Aug 11, 2006 at 11:43:09PM +0200, Maciej Sieczka wrote:
It is online now.
