Dear all,
in r69683 I’ve added few lines to support colors hexadecimal numbers for colors when prefixed by hash. That’s the syntax often used in HTML (CSS) and by other programs and formats.
Now instead of
d.vect map=hospitals color=80:170:255
you can do this:
d.vect map=hospitals color=#50AAFF
which is useful when you are copy pasting colors from somewhere (like the gcolor2).
The limit is that it works only for the places where G_str_to_color() is used. Most notably it doesn’t work in r.colors’ rules file.
This can help with writing scripts but be aware that # starts a comment in Bash, so use quotes.
Please comment,
Vaclav
https://trac.osgeo.org/grass/changeset/69683
2016-10-07 1:58 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
Now instead of
you can do this:
great! Good idea, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Le 7 octobre 2016 09:50:16 GMT+02:00, Martin Landa <landa.martin@gmail.com> a écrit :
Now instead of
you can do this:
Very helpful indeed. Thanks !
Moritz
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
