I'm using 6.4.0RC3 on OSX 10.4.11 (Kyngesburye release) using the WxPython GUI. I set up a where clause for a vector display (ATTR<>'ABC'), which works fine. I then save the workspace as "test.gxw". No problem there.
When I try to open the test.gxw workspace file I get the error message:
Error
Reading workspace file <..../test.gxw>
failed. Invalid file, unable to parse XML document.
<unknown>:17:35: not well-formed (invalid token)
I open up the file using emacs and it immediately flags the "<" in the "<>" field:
<parameter name="where">
<value>ATTR<>'ABC'</value>
</parameter>
since it believes the "<" is opening a markup tag.
I edit the file to change "<>" to <> and try to open the workspace file again. This time the workspace gets loaded just fine. Tried to save with the SQL "cat<10". File saves OK but I get the same error when trying to open that gxw file. I change the "<10" to "<10" and the file opens and the vector displays no problem.
I guess the GXW save facility needs to check for the "<" symbol and replace it with "<"
Joe
The “ampersand-lt-semicolon” got changed to “<” at the nabble site. Just to make sure the post makes sense I’ve changed the previous post. See below… Joe
Subject: SQL inequality and GXW files
I’m using 6.4.0RC3 on OSX 10.4.11 (Kyngesburye release) using the WxPython GUI. I set up a where clause for a vector display (ATTR<>‘ABC’), which works fine. I then save the workspace as “test.gxw”. No problem there.
Error
Reading workspace file <…/test.gxw>
I open up the file using emacs and it immediately flags the “<” in the “<>” field:
ATTR<>'ABC'
since it believes the “<” is opening a markup tag.
I edit the file to change “<>” to “ampersand-lt-semicolon ampersand-gt-semicolon” and try to open the workspace file again. This time the workspace gets loaded just fine. Tried to save with the SQL “cat<10”. File saves OK but I get the same error when trying to open that gxw file. I change the “<10” to “ampersand-lt-semicolon 10” and the file opens and the vector displays no problem.
I guess the GXW save facility needs to check for the “<” symbol and replace it with “ampersand-lt-semicolon”
Joe
2009/3/16 Joe Ostrowski <jtostrowski@comcast.net>:
Error
this bug has been already fixed - wait for RC4 or use relbr64 directly.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
