[GRASS-dev] SQLite 3 "SQL logic error"
Dear all,
I have made some progress on this and think that I have actually
found the reason for this problem.
The error message is issued by this block of C++ code
in gdal-1.6.1/ogr/ogrsf_frmts/sqlite/ogrsqlitetablelayer.cpp
(ca. line 826):
/* Execute the insert. */
    rc = sqlite3_step( hInsertStmt );
    if( rc != SQLITE_OK && rc != SQLITE_DONE )
        CPLError( CE_Failure, CPLE_AppDefined,
                  "sqlite3_step() failed:\n %s",
                  sqlite3_errmsg(hDB) );
        return OGRERR_FAILURE;
I have added some debugging code to the OGR SQLite driver to see
what the SQL statement looks like that actually gets processed
by sqlite3_step().
The output of "v.out.ogr" then was:
Exporting 2898 points/lines...
SQL: 'INSERT INTO 'dem' (WKT_GEOMETRY,'cat','cat_','flt1') VALUES (?,'1','1','75.5')'
SQL: 'INSERT INTO 'dem' (OGC_FID,WKT_GEOMETRY,'cat','cat_','flt1') VALUES (1,?,'2','2','73.57')'
ERROR 1: sqlite3_step() failed:
  SQL logic error or missing database
SQL: 'INSERT INTO 'dem' (OGC_FID,WKT_GEOMETRY,'cat','cat_','flt1') VALUES (1,?,'3','3','75.41')'
Interestingly, the SQL code for the first feature (which gets stored
OK in the DB) differs from that of all the following in that it does
not insert a value into the "OGC_FID" column!
After that, the statements look OK but they are not: "OGC_FID" is
a primary key field, but the same value "1" is generated for all
rows.
Actually, the first statement is the right one! Since it does not
touch the "OGC_FID" field, but that field is properly declared
as an auto-incrementing primary key, the SQLite3 driver takes care
of inserting a proper value by itself.
So it seems to me the fix would be to stop v.out.ogr from creating
an "OGC_FID" value as part of the attribute record for the OGR
feature (after the first record, which is for some reason OK!).
Unfortunately, I know very little about the OGR C API and don't quite
understand how to change the code in v.out.ogr. Could someone more
familiar with that module help out, please?
Ben
P.S.: Why this all seems to be no problem for a PostGIS DBMS completely
eludes me -- perhaps it just ignores wrong values for a PK field and
silently replaces them with correct values...
Benjamin Ducke wrote:
Dear all,
I have been trying in vain to store some very simple GRASS vector
map in an SQLite3 DBMS using v.out.ogr. The data consists of
only 93 3D points with attached integer and double attributes.
No complex shapes, timestamps, text or blobs.
Using v.out.ogr, I get:
for all except the first record, which gets stored correctly
in the (new) database. It is not possible to test this with
an existing SQLite database file, because v.out.ogr in RC5
does not support the OGR "update" action.
I have searched the Trac system for clues and found one ticket
that may be related: http://trac.osgeo.org/grass/ticket/548
I have also tried this with different versions of SQLite and
on different Linux systems, but always with the same result.
My setup:
32Bit Gentoo Linux
GRASS 6.4RC5
SQLite 3.6.16
GDAL 1.6.1 (SQLite driver using native code, not linked
to spatialite)
Is there anybody here experiencing the same problems?
Any idea where to start looking? I am very interested in
making external SQLite support via OGR work, but have no
clue where to start looking to resolve the problem, so
any ideas are more than welcome!
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
grass-dev mailing list
grass-dev@lists.osgeo.org
