[GRASS-dev] standalone installer cleanup
re. r57342, the PROJ_LIB variable is needed by e.g. cs2cs used by some scripts, and I'm not sure if the removal of tcl/tk from the PATH was intentional or just an over-merge, but fwiw a functioning gis.m should remain as an alternative in case there are multiple-python install problems (as ongoing) or just because someone likes to use it for whatever reason.
thanks,
Hamish
2013/8/2 Hamish <hamish_b@yahoo.com>:
are you sure about that?, proj lib in the path (`extralib`) or it
refers to share stuff?
it's intentional. BTW, tcl/tk is currently only GUI which is working
in standalone installer. wxGUI is broken thanks to MAXREPEAT problem.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2013/8/2 Martin Landa <landa.martin@gmail.com>:
quickly checking proj manual. IAIW, PROJ_LIB should point to the
`share` directory. If so I will restore this environmental variable.
Martin
hi,
Martin Landa wrote
2013/8/2 Martin Landa &lt;
landa.martin@
&gt;:
2013/8/2 Hamish &lt;
hamish_b@
&gt;:
scripts,
Martin
grass-dev mailing list
grass-dev@.osgeo
thanks for restoring.
have a quick look in
wingrass, gdal, proj4
http://trac.osgeo.org/grass/ticket/1201
and
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001102.html
They should all be include with wingrass.
GDAL_DATA=C:\OSGeo4W\share\gdal
PROJ_LIB=C:\OSGeo4W\share\proj
GEOTIFF_CSV=C:\OSGeo4W\share\epsg_csv
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/standalone-installer-cleanup-tp5070418p5070434.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
done in all active branches. Martin
