I just did another CVS update, made distclean, reconfigured, recompiled.
Still the same problems.
This is the dump of "v.out.ogr -help":
Parameters:
output Name for output vector map
cat Feature type. Combination of types is not supported by all
formats.
options: point,kernel,centroid,line,boundary,area,face
default: line,boundary
dsn OGR output datasource name. For example:
ESRI Shapefile: filename or directory for storage
MapInfo File: filename or directory for storage
olayer OGR layer name. If not specified, input name is used.
ESRI Shapefile: shapefile name
MapInfo File: mapinfo file name
cats Category values
Example: 1,3,7-9,13
format OGR format
options:
ESRI_Shapefile,MapInfo_File,TIGER,S57,DGN,Memory,CSV,GML,
KML,
default: ESRI_Shapefile
dsco OGR dataset creation option (format specific, NAME=VALUE)
default:
lco OGR layer creation option (format specific, NAME=VALUE)
default:
As you can see, "input" is missing, option "type" is called "cat", I
don't get option "layer" anymore and option "cats" has been added
instead. Pretty weird.
In addition v.in.ogr now complains about not being able to find object
"G_str_to_sql" in "libgrass_gis.6.3.cvs.dll".
This is a MINGW compile, mind you.
Ben
Hamish wrote:
Benjamin wrote:
I just did a fresh rebuild from CVS an hour ago and noticed that
standard option declarations (G_OPT_V_FIELD, G_OPT_R_OUTPUT,
G_OPT_V_MAP) are no longer working. Options declared this way get
totally messed up. Have a look at v.out.ogr for an an example.
Markus:
I bet that you need to run
make distclean
before recompiling.
Benjamin:
Sorry, no luck. Did a distclean and recompiled. Same problem.
Do you have it, too?
Looks ok for me using yesterday's CVS. What do the broken bits look
like? Are they taking descriptions etc from another std option?
I did add a new standard option the other day (for fs=), but added it to
the end of the STD_OPT list. I thought doing that would only cause
distclean problems if I had added it to the middle of the list, i.e.
reordering the index.
Hamish
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
