What is the diference betwen G_OPT_R_INPUT and G_OPT_R_MAP ?
if I have a geoprocess has two input raster layers, which of these two options standares I use to define these inputs?
Another related question: what are the values that support the keyword “type” in the definition of the head of the code?
In my example, I implemented a script with python scripting library, it takes two raster layers as inputs and outputs a raster layer.
The defintion header is:
option: G_OPT_R_INPUT
type : string
type : string
It is correct?
Or, the correct is:
type : raster
type : raster
Thanks in advanced
Pablo J. Zader Universidad Nacional de Córdoba
GIS and remote sensing developer –
Lic. en Cs. de la Computación
Mgtr. Aplicaciones en Espaciales de Alerta y Respuesta Temprana a Emergencias – pablo.zader@gmail.com
"Los Grandes Hombres hablan sobre ideas… Los Hombres Promedio hablan sobre cosas… Los Hombres Pequeños hablan… de otros Hombres.
"type" in the definition of the head of the code?
takes
type : string
type : string
It is correct?
Or, the correct is:
type : raster
type : raster
Thanks in advanced
*Pablo J. Zader*
*Universidad Nacional de Córdoba*
*GIS and remote sensing developer--*
*Lic. en Cs. de la Computación*
*Mgtr. Aplicaciones en Espaciales de Alerta y Respuesta Temprana a
Emergencias*
pablo.zader@
pablo.zader@
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
grass-dev mailing list
The key for G_OPT_R_INPUT is "input", while the key for G_OPT_R_MAP is
"map". Typically, you would use G_OPT_R_INPUT if the module also has
an output option and G_OPT_R_MAP if the module does not have an output
option, e.g. r.info.
HTH,
Markus M
type : string
type : string
It is correct?
Or, the correct is:
type : raster
type : raster
Thanks in advanced
Pablo J. Zader
Emergencias
Los Hombres Promedio hablan sobre cosas...
