[GRASS-dev] standardized options
Dear Devs,
in r57084 Martin has added standardized options to r.ipso (thanks!). I would like to learn more about their use, particularly, does it exist a standard variable defined for taking a path as input? (Not a path+file name as G_OPT_F_INPUT). For example this is useful in the case that a module produces some pictures and/or csv files and the user wants to set a folder for storing them. I digged into [1] but I seem not to find what I need. Should I just take the path as a string? Giving to the user the possibility to browse the folders instead of indicating a path would be IMHO more convenient. Could anyone point me out where to read in order to learn more about that?
Thanks!
madi
[1] http://grass.osgeo.org/programming7/gis_8h_source.html
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
You could try G_OPT_M_DIR. The comment says "directory input" but it
should also work for output, all it should return is the path to a
folder.
Markus M
On Mon, Jul 15, 2013 at 5:42 PM, Margherita Di Leo
<dileomargherita@gmail.com> wrote:
Dear Devs,
about that?
Thanks!
madi
Best regards,
Via Fermi, 2749
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Madi,
that’s interesting and there is even a G_OPT_R_ELEV, I was not aware of it.
You can have a look into these:
http://grass.osgeo.org/programming7/parser__standard__options_8c_source.html
http://grass.osgeo.org/programming7/parser__standard__options_8c.html
http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
Vaclav
On Tue, Jul 16, 2013 at 6:31 AM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
You could try G_OPT_M_DIR. The comment says “directory input” but it
folder.
Markus M
Dear Devs,
about that?
Thanks!
madi
Best regards,
Via Fermi, 2749
