[GRASS-dev] standarizing range syntax
Currently, due to its history, GRASS has various ways of designating a range of values.
In raster displays (d.rast) ranges are expressed as 'n-n';
for color tables, they are implied but not explicitly given;
for raster reclass maps (r.reclass), they are expressed as 'n thru n'
for raster recode (r.recode), they are expressed as 'n:n';
for vector reclass (actually a recode, v.reclass), ranges are expressed in SQL syntax
At least for rasters, I'd like to suggest that we standardize range notation.
I recommend 'n-n'. It is compact, widely recognized, and doesn't use a misspelled english word ("thru"). The syntax 'n:n' is used in some programming, but not a lot beyond that.
I suppose that each module might also accept it's old non-standard syntax, too, to maintain backward compatibility for scripts.
Michael
range of values.
notation.
One issue with "m-n" is that it could be quite easy to inadvertently
write code which doesn't handle negative values correctly, e.g.
"-10--5". IMHO, it's also less clear than "-10:-5".
range of values.
notation.
OK. What about "m to n"?
Michael
range of values.
'n thru n' for raster recode (r.recode), they are expressed as
'n:n'; for vector reclass (actually a recode, v.reclass),
v.extract user the standard parser option G_OPT_V_CATS:
    list Category values
            Example: 1,3,7-9,13
which I think is fine; cat ranges never fall into the negative.
r.category's cats= option is the same, but its rules file format uses
  cat:Label
or
  val1:val2:Label
r.reclass format is a bit weird, I don't mind changing that.
r.colors rules are used bit differently, so they may not fall into the
scope of this standardization round.
I assume vector modules which take SQL statements do not parse those
statements but pass them intact, in which case I would leave them
as-is.
I would not touch this for grass6, and not stress too much about backwards
compatibility for grass7.
2c,
Hamish
