[GRASS-dev] starting GIPE modules insertion in main svn
Hello list,
I would like to start including two modules from GIPE into main svn:
i.qc.modis: classifies binary Quality flags from MODIS reflectance
products (250 & 500m) into values.
i.albedo: reflectance to albedo for Modis, Landsat5/7, aster, avhrr
Michael, how do we integrate the gipe modules in the GUI?
I have an example of gmmenu.tcl and menudata.py in Addons-svn
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
2008/9/27 Yann Chemin <yann.chemin@gmail.com>:
compilation still fails:
CKAGE=\""grassmods"\"
-I/home/martin/src/grass_trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/qc250a.o -c qc250a.c
qc250a.c: In function 'qc250a':
qc250a.c:14: error: implicit declaration of function 'swab'
make: *** [OBJ.i686-pc-linux-gnu/qc250a.o] Error 1
before moving to main trunk, please standardize messages, etc. see e.g.
http://trac.osgeo.org/grass/changeset/33614
or
http://trac.osgeo.org/grass/changeset/33613
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Right; you need <unistd.h> for swab().
BTW, what purpose does making qc250chan an "unsigned int" serve? CELL
is an "int" and the "unsigned" qualifier doesn't make any difference
to the operations which are actually being performed upon the values.
Also, the fact that the swab() calls are there seems to imply that the
data was imported incorrectly in the first place. If any byte swapping
needs to be done, it should normally be done when the data is
imported.
2008/9/30 Glynn Clements <glynn@gclements.plus.com>:
are there forgiving compilers around, so that this was not required explicitely?
This is on my laptop:
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian
4.3.2-1' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs
--enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr
--enable-shared --with-system-zlib --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --enable-nls
--with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3
--enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc
--enable-mpfr --enable-cld --enable-checking=release
--build=x86_64-linux-gnu --host=x86_64-linux-gnu
--target=x86_64-linux-gnu
Thread model: posix
gcc version 4.3.2 (Debian 4.3.2-1)
The functions were designed out of GRASS, with stronger restrictions
on reading in data.
This should be obsolete in GRASS now indeed.
imported.
My mastering of binary reading is weak, so I guess you make sense,
but technically I would feel weak to modify it. For what I undestand
it was initially meant
(outside of GRASS) to isolate a small number of bits for & comparison.
Yann Chemin
explicitely?
Thread model: posix
I am using also
-fno-common
which helps to catch stuff. Earlier I used even
-Werror-implicit-function-declaration
but at some point it was to restricted (didn't try recently).
By default, "implicit declaration of function ..." only generates a
warning, not an error. However, the resulting binary is likely to
crash if the compiler guesses the function's prototype incorrectly.
IIRC, Markus normally compiles with
-Werror-implicit-function-declaration, which will cause implicit
function definitions to generate an error.
> imported.
it was initially meant (outside of GRASS) to isolate a small number
In that case, I'm guessing that the code was designed for a specific
architecture, one whose byte order is opposite to that used by the
data.
Ultimately, if you don't understand the format, or how the code is
supposed to work, it's probably better not to commit it.
Markus Neteler wrote:
I am using also
-fno-common
I've been using
CFLAGS="-ggdb -Wall -Werror-implicit-function-declaration" ./configure ...
for a long time without any problem.
Hamish
Hi Glynn,
2008/10/1 Glynn Clements <glynn@gclements.plus.com>:
see below about this
I have made that my default compile option now.
> imported.
data.
I agree.
Let me try to remove swab(). It should help clarify things.
Thanks for all,
Yann
Yann Chemin
