Hi Maris,
(cc grass-dev since also others may want to know)
On Sat, Jan 14, 2017 at 4:16 PM, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello, Markus.
I was checking OpenHub and noticed that stats for GRASS and addons
have not been updated for the past 8 months.
If you look at "code locations", it is indicating on a failure 4 months a go: https://www.openhub.net/p/grass_gis/enlistments#
Yes, I am aware of that problem.
As you are listed as a maintainer, could you report an issue about it
to get stats back?
Hello Markus,
I removed all code locations and re-added only trunk (as per OpenHub
suggestion to have trunk only). At the moment it has downloaded 48 of
35343 files. We'll see if it helps.
Also I noticed that our main website First time user page[1] links to
7.0 Quickstart page. Could you fix that?
2017-01-14 22:25 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Maris,
Hello, Markus.
to get stats back?
On Sun, Feb 26, 2017 at 11:47 AM, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello Markus,
I don't see any progress (ok, it incremented from 9 months outdated to 10 :p)
Hello Markus,
I'm monitoring this site: https://www.openhub.net/p/grass_gis/enlistments
It was downloading code by small chunks (~1000 files) with breaks of
several hours and then completely failed. Now it is trying again:
"Downloading source code history (Running 70/29756)"
Judging by forum posts, they are not doing well for a lot of projects.
Māris.
2017-03-10 0:53 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Maris,
Hello Markus,
