Aarrgh!
I reupdated from trunk, recompiled TclTk from source, reinstalled your newest frameworks and I still get errors compiling GRASS 7 on my iMac. AFAICT, same OS and setup as my MacBook: OS X 10.5.4 up to date, same config string.
Below are the errors. They simply don't make any sense. Neither of these sections of the code have been altered in a while. But that shouldn't matter. What compiles on my MacBook *ought* to compile on my iMac.
Any suggestions as to where to start to look to sort this out?
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
============= errors ==================
anthgradpc7:grass7_src cmbarton$ cd ./lib/external/shapelib
anthgradpc7:shapelib cmbarton$ make
gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -arch i386 -Os -fno-common -DPACKAGE=\""grasslibs"\" -DPACKAGE=\""grasslibs"\" -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/safileio.o -c safileio.c
safileio.c:83: error: syntax error before ‘SADFOpen’
safileio.c: In function ‘SADFOpen’:
safileio.c:86: error: ‘SAFile’ undeclared (first use in this function)
safileio.c:86: error: (Each undeclared identifier is reported only once
safileio.c:86: error: for each function it appears in.)
safileio.c:86: error: syntax error before ‘fopen’
safileio.c: At top level:
safileio.c:93: error: syntax error before ‘SADFRead’
safileio.c:93: error: syntax error before ‘SAOffset’
safileio.c: In function ‘SADFRead’:
safileio.c:96: error: ‘SAOffset’ undeclared (first use in this function)
safileio.c:96: error: syntax error before ‘fread’
safileio.c:104: error: syntax error before ‘SADFWrite’
safileio.c:104: error: syntax error before ‘SAOffset’
safileio.c: In function ‘SADFWrite’:
safileio.c:107: error: ‘SAOffset’ undeclared (first use in this function)
safileio.c:107: error: syntax error before ‘fwrite’
safileio.c:115: error: syntax error before ‘SADFSeek’
safileio.c:115: error: syntax error before ‘file’
safileio.c: In function ‘SADFSeek’:
safileio.c:118: error: ‘SAOffset’ undeclared (first use in this function)
safileio.c:118: error: syntax error before ‘fseek’
safileio.c:125: error: syntax error before ‘SADFTell’
safileio.c:125: error: syntax error before ‘file’
safileio.c: In function ‘SADFTell’:
safileio.c:128: error: ‘SAOffset’ undeclared (first use in this function)
safileio.c:128: error: syntax error before ‘ftell’
safileio.c:135: error: syntax error before ‘file’
safileio.c: In function ‘SADFFlush’:
safileio.c:138: error: ‘file’ undeclared (first use in this function)
safileio.c:145: error: syntax error before ‘file’
safileio.c: In function ‘SADFClose’:
safileio.c:148: error: ‘file’ undeclared (first use in this function)
safileio.c:175: error: syntax error before ‘*’ token
safileio.c: In function ‘SASetupDefaultHooks’:
safileio.c:178: error: ‘psHooks’ undeclared (first use in this function)
make: *** [OBJ.i386-apple-darwin9.4.0/safileio.o] Error 1
cd ./db/drivers/dbf
anthgradpc7:dbf cmbarton$ make
gcc -L/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/lib -arch i386 -Os -arch i386 -Os -o /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/driver/db/dbf OBJ.i386-apple-darwin9.4.0/column.o OBJ.i386-apple-darwin9.4.0/cursor.o OBJ.i386-apple-darwin9.4.0/db.o OBJ.i386-apple-darwin9.4.0/dbfexe.o OBJ.i386-apple-darwin9.4.0/describe.o OBJ.i386-apple-darwin9.4.0/driver.o OBJ.i386-apple-darwin9.4.0/error.o OBJ.i386-apple-darwin9.4.0/execute.o OBJ.i386-apple-darwin9.4.0/fetch.o OBJ.i386-apple-darwin9.4.0/listtab.o OBJ.i386-apple-darwin9.4.0/main.o OBJ.i386-apple-darwin9.4.0/select.o OBJ.i386-apple-darwin9.4.0/str.o OBJ.i386-apple-darwin9.4.0/table.o OBJ.i386-apple-darwin9.4.0/create_table.o -lgrass_dbmidriver -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_sqlp -lgrass_shape -lgrass_dbstubs -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lz
ld: library not found for -lgrass_shape
collect2: ld returned 1 exit status
make: *** [/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/driver/db/dbf] Error 1
