[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1144 (master - f4d9c2a)
Build #1144 is still failing.
5 minutes and 10 seconds
Markus Neteler
f4d9c2a Changeset →
r.walk manual: use HTML code for accented chars
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@68368 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
