[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1839 (master - 81d8550)
Build #1839 is still failing.
11 minutes and 26 seconds
Anna Petrášová
81d8550 Changeset →
wxGUI: uninitialize aui manager when destroying map display to fix #3237
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70296 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
