[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1895 (master - f866496)
Build #1895 is still failing.
4 minutes and 49 seconds
Václav Petráš
f866496 Changeset →
wxGUI: Ctrl+W is already used in menu, improve descriptions
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70448 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
