5 minutes and 16 seconds |
Václav Petráš |
wxGUI: menu item and shortcut to re-render all map displays git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70449 15284696-431f-4ddb-bdfa-cd5b030d7da7 |
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI Need help? Mail support! Choose who receives these build notification emails in your configuration file. |
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
