42 minutes and 8 seconds |
Václav Petráš |
wxGUI/pyedit: Debug format is percent not format function git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70459 15284696-431f-4ddb-bdfa-cd5b030d7da7 |
System message:
We are seeing delays for sudo-enabled Linux builds (public and private). You can follow the updates here. Thank you for your patience.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI Need help? Mail support! Choose who receives these build notification emails in your configuration file. |
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
