[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1908 (master - 8875135)
Build #1908 is still failing.
1 hour, 12 minutes, and 3 seconds
Moritz Lennert
8875135 Changeset →
i.zc: threshold was not read correctly and had no effect
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70477 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
