[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1909 (master - 05df514)
Build #1909 is still failing.
7 minutes and 11 seconds
Yann Chemin
05df514 Changeset →
improved Warning description
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70479 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
Is Travis doing OK ?
On 04/02/2017 14:30, Travis CI wrote:
Build Update for GRASS-GIS/grass-ci
Build: #1909
Status: Still Failing
Duration: 7 minutes and 11 seconds
Commit: 05df514 (master)
Author: Yann Chemin
Message: improved Warning description
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/8875135d3c9f...05df514ab24f
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/198318865
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
See [1] and following.
Moritz
[1] https://lists.osgeo.org/pipermail/grass-dev/2017-January/084071.html
Build: #1909
Author: Yann Chemin
View the changeset:
Sorry for the noise. The Mac compilation had 3rd party dependencies and other issues, see e.g.
https://trac.osgeo.org/grass/ticket/3250
I committed
https://trac.osgeo.org/grass/changeset/70483
which revers the Mac part of
https://trac.osgeo.org/grass/changeset/68652
The following commit also un-hides the scripts which are in the .travis dir.
https://trac.osgeo.org/grass/changeset/70484
We can consider renaming .travis dir to travis only. But I think .travis.yml must have exactly this name.
Rainer, I added you to the GRASS GIS org on GitHub, you should be able to transfer the ownership of the Homebrew repo if you decide to do so in order to give more people direct access to that code. I suggest using Travis cron job which can be setup in Travis if one have access to the repo.
https://docs.travis-ci.com/user/cron-jobs/
Vaclav
