[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#2147 (master - a68bbd0)
Build #2147 is still failing.
37 seconds
Markus Neteler
a68bbd0 Changeset →
r.stats.quantile and r.stats.zonal manuals: examples added
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71055 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
We have updated our sudo-enabled Precise images! Read our blog post for more details. Thank you! :rocket: :sparkles:
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
